Precursors of the IT Nation: Computer Use and Control in Swedish Society, 1955–1985 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is a presentation of a research project that aims at writing the history of computing in Sweden in the mainframe age from a user perspective. Rather than beginning with the history of hardware, this project takes as its point of departure the way in which actors in different sectors of society used computer technology in order to achieve a higher degree of control over crucial processes, whether through electronic data processing systems, process control or technical/scientific computation.
978-3-642-23315-9_48_Chapter.pdf (115.64 Ko) Télécharger le fichier
hal-01564631 , version 1 (19-07-2017)
Paternité
Isabelle Dussauge, Johan Gribbe, Arne Kaijser, Per Lundin, Julia Peralta, et al.. Precursors of the IT Nation: Computer Use and Control in Swedish Society, 1955–1985. 3rd History of Nordic Computing (HiNC), Oct 2010, Stockholm, Sweden. pp.425-432, ⟨10.1007/978-3-642-23315-9_48⟩. ⟨hal-01564631⟩
95 Consultations
95 Téléchargements
