The Application Research of Neural Network in Embedded Intelligent Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Xiaodong Liu
  • Fonction : Auteur
Hubin Deng
  • Fonction : Auteur
  • PersonId : 1013071
Jinhua Wang
  • Fonction : Auteur
Neural network which can adapt the sample data by training has good fault-tolerance and can be used in the field of intelligence widely. In the embedded system, restricted to the resources and the capacity of processor, the neural network application has a series of problems, such as losing timelines and the system could be collapsed easily. This article discusses how to use limited memory, processor and external equipment resources to achieve the neural network algorithm for improving the universality of detection system and adaptive ability in the embedded intelligent measuring system.
978-3-642-18369-0_43_Chapter.pdf (140.22 Ko) Télécharger le fichier
hal-01564823 , version 1 (19-07-2017)
Paternité
Xiaodong Liu, Dongzhou Ning, Hubin Deng, Jinhua Wang. The Application Research of Neural Network in Embedded Intelligent Detection. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.376-381, ⟨10.1007/978-3-642-18369-0_43⟩. ⟨hal-01564823⟩
52 Consultations
49 Téléchargements
