Analysis and Implementation of Embedded SNMP Agent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hubin Deng
  • Fonction : Auteur
  • PersonId : 1013096
With the extensive application of network devices and the rapid development of embedded technology, network management of embedded devices becomes increasingly complicated. SNMP management is the most widely used network management system(NMS). Most of the network components used in enterprise network have built-in network agents that can respond to an SNMP network management system. By analyzing the SNMP (Simple Network Management Protocol) and base on NET-SNMP development kit, discuss the construction of MIB modules and code conversion and complete embedded SNMP Agent extension. Through network management tools to verify the SNMP agent on the network management functions of the embedded device.
978-3-642-18369-0_11_Chapter.pdf (678.53 Ko) Télécharger le fichier
hal-01564851 , version 1 (19-07-2017)
Paternité
Hubin Deng, Guiyuan Liu, Lei Zhang. Analysis and Implementation of Embedded SNMP Agent. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.96-102, ⟨10.1007/978-3-642-18369-0_11⟩. ⟨hal-01564851⟩
112 Consultations
600 Téléchargements
