Design of Tread Flange Injection Mold Based on Pro/E - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Huilan Zhou
  • Fonction : Auteur
  • PersonId : 1013106
In the paper, analyzing the tread flange structure characteristics, its injection mold is designed and the maneuvering tread demolding way is applied to get out flang tread. When designing demolding parts, hydraulic pressure motor and chain-gear mechanism are used. Besides, parting plane and the forming parts can be gained automatically in Pro/E(Pro/Engineer Wildfire3.0) and standard moldbase can be achieved by EMX4.1 including gating, cooling, and guiding system, etc. The designing ways and structure is proved rational and can be taken as reference for the similar injection mold especially for those with longer tread.
978-3-642-18369-0_66_Chapter.pdf (201.92 Ko) Télécharger le fichier
hal-01564861 , version 1 (19-07-2017)
Paternité
Huilan Zhou. Design of Tread Flange Injection Mold Based on Pro/E. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.555-562, ⟨10.1007/978-3-642-18369-0_66⟩. ⟨hal-01564861⟩
56 Consultations
149 Téléchargements
