Evaluation of the Rural Informatization Level in Central China Based on Catastrophe Progression Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lingxian Zhang
  • Fonction : Auteur
  • PersonId : 987348
Daoliang Li
  • Fonction : Auteur
  • PersonId : 972201
This paper developed a methodology based on the catastrophe theory for estimating the rural informatization level in central China, and took evaluation of the rural informatization level among the six provinces of central China as an example to test the effectiveness of the method. Taking data from reference and constructing the hierarchy based on catastrophe progression method, it was calculated the scores of rural informatization level among the six provinces of central China using normalizing formula. The results are found to be coincident with practical situation, so it proves the catastrophe progression method works well.
978-3-642-18369-0_80_Chapter.pdf (411.28 Ko) Télécharger le fichier
hal-01564887 , version 1 (19-07-2017)
Paternité
Lingxian Zhang, Xue Liu, Zetian Fu, Daoliang Li. Evaluation of the Rural Informatization Level in Central China Based on Catastrophe Progression Method. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.672-679, ⟨10.1007/978-3-642-18369-0_80⟩. ⟨hal-01564887⟩
76 Consultations
64 Téléchargements
