Modeling and Performance Analysis of Giant Magnetostrictive Microgripper with Flexure Hinge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to improve the steady output of micrgripper, the giant magnetostrictive micrgripper with flexure hinge is taken as the research object. Its structure and working principle are presented .the static performance experiments are done and the better linear work domain is found. On the basis of that the dynamic model of the microgripper is established and the formula of the microgripper’s output displacement is deduced. the relationship between the microgripper’s parameters and responses are analyzed and open-loop simulation step is done, The simulation results show the giant magnetostrictive material(GMM) rod damp effects on the response time and its quality has little influence.
978-3-642-18369-0_27_Chapter.pdf (208.53 Ko) Télécharger le fichier
hal-01564890 , version 1 (19-07-2017)
Paternité
Qinghua Cao, Quanguo Lu, Junmei Xi, Jianwu Yan, Changbao Chu. Modeling and Performance Analysis of Giant Magnetostrictive Microgripper with Flexure Hinge. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.237-245, ⟨10.1007/978-3-642-18369-0_27⟩. ⟨hal-01564890⟩
372 Consultations
55 Téléchargements
