Study on Autonomous Path Planning by Mobile Robot for Road Nondestructive Testing Based on GPS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lunhui Xu
  • Fonction : Auteur
  • PersonId : 1013131
Fan Ye
Yanguo Huang
  • Fonction : Auteur
  • PersonId : 1013133
This paper analyses the statements of video imaging, CT, infrared thermography and radiography applied in the road nondestructive testing, and design a path planning mobile robot with GPS positioning which can remarkably increase the efficient of road nondestructive testing. Besides, appropriate algorithm for nondestructive testing on the road autonomous mobile robot path planning is given. This method is simplicity, versatility, and efficiency. The mobile robot are selected for example and the simulation results represent the effectiveness of this method.
978-3-642-18369-0_37_Chapter.pdf (154.49 Ko) Télécharger le fichier
hal-01564891 , version 1 (19-07-2017)
Paternité
Lunhui Xu, Fan Ye, Yanguo Huang. Study on Autonomous Path Planning by Mobile Robot for Road Nondestructive Testing Based on GPS. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.321-332, ⟨10.1007/978-3-642-18369-0_37⟩. ⟨hal-01564891⟩
106 Consultations
98 Téléchargements
