AE Feature Analysis on Welding Crack Defects of HG70 Steel Used by Truck Crane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In present paper, using Acoustic Emission (AE) as a ultrasonic technique, Welding crack has been investigated on the HG70 steel used by truck crane during three-point bending test was carried out. The study shows that the activity of AE increases greatly during the welding crack initiates and propagates, and the distributing range of AE characteristic parameters can be fixed. AE signals of welding crack initiation and expansion are typical sudden signals which have a different spectrum energy distribution range with that of unstable crack propagation.
978-3-642-18369-0_9_Chapter.pdf (220.48 Ko) Télécharger le fichier
hal-01564894 , version 1 (19-07-2017)
Paternité
Yantao Dou, Xiaoli Xu, Wei Wang, Siqin Pang. AE Feature Analysis on Welding Crack Defects of HG70 Steel Used by Truck Crane. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.78-88, ⟨10.1007/978-3-642-18369-0_9⟩. ⟨hal-01564894⟩
90 Consultations
120 Téléchargements
