Convexity-preserving rigid motions of 2D digital objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rigid motions on R^2 are isometric and thus preserve the geometry and topology of objects. However, this important property is generally lost when considering digital objects defined on Z^2 , due to the digitization process from R^2 to Z^2. In this article, we focus on the convexity property of digital objects, and propose an approach for rigid motions of digital objects which preserves this convexity. The method is extended to non-convex objects, based on the concavity tree representation.
Paper15.pdf (687.4 Ko) Télécharger le fichier
Ngo DGCI 2017 Poster.pdf (976.02 Ko) Télécharger le fichier
hal-01565028 , version 1 (19-07-2017)
Phuc Ngo, Yukiko Kenmochi, Isabelle Debled-Rennesson, Nicolas Passat. Convexity-preserving rigid motions of 2D digital objects. Discrete Geometry for Computer Imagery (DGCI), 2017, Vienna, Austria. pp.69-81, ⟨10.1007/978-3-319-66272-5_7⟩. ⟨hal-01565028⟩
439 Consultations
216 Téléchargements
