Numerical analysis of the mixed finite element method for the neutron diffusion eigenproblem with heterogeneous coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We study first the convergence of the finite element approximation of the mixed diffusion equations with a source term, in the case where the solution is of low regularity. Such a situation commonly arises in the presence of three or more intersecting material components with different characteristics. Then we focus on the approximation of the associated eigenvalue problem. These studies are carried out without, and then with a domain decomposition method. The domain decomposition method can be non-matching in the sense that the traces of the finite element spaces may not fit at the interface between subdomains. Finally, numerical experiments illustrate the accuracy of the method.
CGJK17.pdf (829.99 Ko) Télécharger le fichier
hal-01566179 , version 1 (20-07-2017)
hal-01566179 , version 2 (09-12-2017)
  • HAL Id : hal-01566179 , version 1
Patrick Ciarlet, Léandre Giret, Erell Jamelot, Félix D. Kpadonou. Numerical analysis of the mixed finite element method for the neutron diffusion eigenproblem with heterogeneous coefficients. 2017. ⟨hal-01566179v1⟩
693 Consultations
645 Téléchargements
