New interface
Journal articles
Approximate and exact controllability of linear difference equations
Abstract : In this paper, we study approximate and exact controllability of the linear difference equation $x(t) = \sum_{j=1}^N A_j x(t - \Lambda_j) + B u(t)$ in $L^2$, with $x(t) \in \mathbb C^d$ and $u(t) \in \mathbb C^m$, using as a basic tool a representation formula for its solution in terms of the initial condition, the control $u$, and some suitable matrix coefficients. When $\Lambda_1, \dotsc, \Lambda_N$ are commensurable, approximate and exact controllability are equivalent and can be characterized by a Kalman criterion. This paper focuses on providing characterizations of approximate and exact controllability without the commensurability assumption. In the case of two-dimensional systems with two delays, we obtain an explicit characterization of approximate and exact controllability in terms of the parameters of the problem. In the general setting, we prove that approximate controllability from zero to constant states is equivalent to approximate controllability in $L^2$. The corresponding result for exact controllability is true at least for two-dimensional systems with two delays.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01575576
Contributor : Mario Sigalotti Connect in order to contact the contributor
Submitted on : Wednesday, April 18, 2018 - 11:00:09 AM
Last modification on : Friday, August 5, 2022 - 12:02:01 PM
EqDiffControl.pdf
Identifiers
Citation
Yacine Chitour, Guilherme Mazanti, Mario Sigalotti. Approximate and exact controllability of linear difference equations. Journal de l'École polytechnique — Mathématiques, 2020, 7, pp.93--142. ⟨10.5802/jep.112⟩. ⟨hal-01575576v2⟩
Share
Metrics
Record views
824
Files downloads
861
