Surface reconstruction by computing restricted Voronoi cells in parallel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2017
Dobrina Boltcheva
  • Fonction : Auteur
  • PersonId : 884271
Bruno Levy
We present a method for reconstructing a 3D surface triangulation from an input point set. The main component of the method is an algorithm that computes the restricted Voronoi diagram. In our specific case, it corresponds to the intersection between the 3D Voronoi diagram of the input points and a set of disks centered at the points and orthogonal to the estimated normal directions. The method does not require coherent normal orientations (just directions). Our algorithm is based on a property of the restricted Voronoi cells that leads to an embarrassingly parallel implementation. We experimented our algorithm with scanned point sets with up to 100 million vertices that were processed within few minutes on a standard computer. The complete implementation is provided.
CAD17.pdf (16.19 Mo) Télécharger le fichier
hal-01596553 , version 1 (28-09-2017)
Dobrina Boltcheva, Bruno Levy. Surface reconstruction by computing restricted Voronoi cells in parallel. Computer-Aided Design, 2017, 90, pp.123 - 134. ⟨10.1016/j.cad.2017.05.011⟩. ⟨hal-01596553⟩
770 Consultations
939 Téléchargements
