A reconciliation-driven approach of case-based prediction: state of the art, method overview and application in food science - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
This chapter proposes an approach to generate predictions for decision support issues. It relies on case-based and reconciliation methods, using an ontology. The objective of the chapter is to provide an overview of the state of the art, but also to describe the proposed method and to illustrate it on a concrete application. In this approach, a reconciliation stage identifies groups of rules expressing a common experimental tendency. A prediction stage generates new rules, using both experimental tendencies obtained in the previous stage and new experimental descriptions. The method has been tested within a case study concerning food quality management. It has been compared to a classic predictive approach, leading to promising results in terms of accuracy, completeness and error rate.
Fichier non déposé
hal-01605378 , version 2 (18-02-2016)
hal-01605378 , version 1 (02-10-2017)
  • HAL Id : hal-01605378 , version 1
  • PRODINRA : 405500
Fatiha Saïs, Rallou Thomopoulos. A reconciliation-driven approach of case-based prediction: state of the art, method overview and application in food science. Case-Based Reasoning: Strategies, Developments and Applications, Nova Science Publishers, 2015, Electrical Engineering Developments, 978-1-63483-705-7. ⟨hal-01605378v1⟩
548 Consultations
198 Téléchargements
