On numerical construction of homogeneous Lyapunov functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of synthesis of a homogeneous Lyapunov function for an asymptotically stable homogeneous system is studied. For systems with a nonnegative degree of homogeneity, a numeric procedure is proposed, which provides a digital representation of a homogeneous Lyapunov function. The results are illustrated by two planar examples of linear and nonlinear systems.
CDC17_1137_FIp.pdf (433 Ko) Télécharger le fichier
hal-01611979 , version 1 (06-10-2017)
  • HAL Id : hal-01611979 , version 1
Denis Efimov, Rosane Ushirobira, Jaime A. Moreno, Wilfrid Perruquetti. On numerical construction of homogeneous Lyapunov functions. 56th IEEE Conference on Decision and Control (CDC), Dec 2017, Melbourne, Australia. ⟨hal-01611979⟩
229 Consultations
330 Téléchargements
