Coping with silent and fail-stop errors at scale by combining replication and checkpointing
Faire face aux pannes et aux erreurs silencieuses en combinant checkpoints et réplication
This paper provides a model and an analytical study of replication as a technique
to detect and correct silent errors, as well as to cope with both silent and fail-stop errors on
large-scale platforms. Fail-stop errors are immediately detected, unlike silent errors for which
a detection mechanism is required. To detect silent errors, many application-specific techniques
are available, either based on algorithms (ABFT), invariant preservation or data analytics, but
replication remains the most transparent and least intrusive technique. We explore the right level
(duplication, triplication or more) of replication for two frameworks: (i) when the platform is
subject only to silent errors, and (ii) when the platform is subject to both silent and fail-stop
errors. A higher level of replication is more expensive in terms of resource usage but enables
to tolerate more errors and to correct some silent errors, hence there is a trade-off to be found.
Replication is combined with checkpointing and comes with two flavors: process replication and group replication. Process replication applies to message-passing applications with communicating
processes. Each process is replicated, and the platform is composed of process pairs, or triplets.
Group replication applies to black-box applications, whose parallel execution is replicated several
times. The platform is partitioned into two halves (or three thirds). In both scenarios, results
are compared before each checkpoint, which is taken only when both results (duplication) or two
out of three results (triplication) coincide. If not, one or more silent errors have been detected,
and the application rolls back to the last checkpoint, as well as when fail-stop errors have struck.
We provide a detailed analytical study for all of these scenarios, with formulas to decide, for each
scenario, the optimal parameters as a function of the error rate, checkpoint cost, and platform size.
We also report a set of extensive simulation results that nicely corroborates the analytical model.
Ce rapport propose un modèle et une étude analytique de la réplication en tant
que technique pour détecter et corriger les erreurs silencieuses. Bien que d’autres techniques
existent pour les applications HPC, basées sur des algorithmes (ABFT), préservation d’invariant,
ou analyse de données, la réplication reste la technique la plus transparente et la moins intrusive.
Nous explorons le bon niveau (duplication, triplication ou plus) dans deux cadres différents : (i)
quand la plateforme est soumise seulement aux erreurs silencieuses, et (ii) lorsque la plateforme
est soumise à la fois aux pannes et aux erreurs silencieuses. Un niveau de réplication élevé est plus
coûteux en terme de ressources utilisées, mais tolère un plus grand nombre d’erreurs, il y a donc
un équilibre à trouver. La réplication est combinée avec des checkpoints et se présente sous deux
formes : réplication de processus et réplication de groupe. La réplication de processus s’applique
aux applications à passage de messages avec des processus communicants. Chaque processus est
répliqué, et la plate-forme est composée de paires, ou triplets de processus. La réplication de groupe
s’applique à des applications type boîte noire, dont l’exécution parallèle est répliquée plusieurs fois.
La plate-forme est alors partitionnée en deux moitiés (ou trois tiers). Dans les deux scénarios,
les résultats sont comparés avant chaque checkpoint, qui est effectué seulement lorsque les deux
résultats (duplication) ou deux sur trois (triplication) coïncident. Sinon, une ou plusieurs erreurs
silencieuses ont été détectées, et l’application redémarre depuis le dernier checkpoint, de la même
façon que lorsqu’une panne survient. Nous proposons une étude analytique détaillée des deux
scénarios ainsi que les paramètres optimaux fonction du taux d’erreur, du coût du checkpoint, et
de la taille de la plate-forme. Nous donnons également les résultats d’un ensemble de simulations
qui viennent corroborer le modèle analytique.
