Journal articles
A Visual Performance Analysis Framework for Task-based Parallel Applications running on Hybrid Clusters
Abstract : Programming paradigms in High-Performance Computing have been shifting towards task-based models which are capable of adapting readily to heterogeneous and scalable supercomputers. The performance of task-based application heavily depends on the runtime scheduling heuristics and on its ability to exploit computing and communication resources. Unfortunately, the traditional performance analysis strategies are unfit to fully understand task-based runtime systems and applications: they expect a regular behavior with communication and computation phases, while task-based applications demonstrate no clear phases. Moreover, the finer granularity of task-based applications typically induces a stochastic behavior that leads to irregular structures that are difficult to analyze. Furthermore, the combination of application structure, scheduler, and hardware information is generally essential to understand performance issues. This paper presents a flexible framework that enables one to combine several sources of information and to create custom visualization panels allowing to understand and pinpoint performance problems incurred by bad scheduling decisions in task-based applications. Three case-studies using StarPU-MPI, a task-based multi-node runtime system, are detailed to show how our framework can be used to study the performance of the well-known Cholesky factorization. Performance improvements include a better task partitioning among the multi-(GPU,core) to get closer to theoretical lower bounds, improved MPI pipelining in multi-(node,core,GPU) to reduce the slow start, and changes in the runtime system to increase MPI bandwidth, with gains of up to 13% in the total makespan.
Complete list of metadata
Cited literature [54 references]  Display  Hide  Download
https://hal.inria.fr/hal-01616632
Contributor : Samuel Thibault Connect in order to contact the contributor
Submitted on : Tuesday, July 17, 2018 - 2:44:56 PM
Last modification on : Tuesday, May 11, 2021 - 11:37:38 AM
Long-term archiving on: : Thursday, October 18, 2018 - 3:42:35 PM
File
CCPE_article_submitted_2018_02...
Identifiers
Citation
Vinicius Garcia Pinto, Lucas Schnorr, Luka Stanisic, Arnaud Legrand, Samuel Thibault, et al.. A Visual Performance Analysis Framework for Task-based Parallel Applications running on Hybrid Clusters. Concurrency and Computation: Practice and Experience, Wiley, 2018, 30 (18), pp.1-31. ⟨10.1002/cpe.4472⟩. ⟨hal-01616632v2⟩
Share
Metrics
Record views
999
Files downloads
1773
