Analysis of the Riemann Problem for a shallow water model with two velocities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2018
Some shallow water type models describing the vertical profile of the horizontal velocity with several degrees of freedom have been recently proposed. The question addressed in the current work is the hyperbolicity of a shallow water model with two velocities. The model is written in a nonconservative form and the analysis of its eigenstructure shows the possibility that two eigenvalues coincide. A definition of the nonconservative product is given which enables us to analyse the resonance and coalescence of waves. Eventually, we prove the well-posedness of the two dimensional Riemann problem with initial condition constant by half-plane.
Multicouche_V1.0.pdf (466.86 Ko) Télécharger le fichier
hal-01618722 , version 1 (18-10-2017)
hal-01618722 , version 2 (19-10-2017)
Nina Aguillon, Emmanuel Audusse, Edwige Godlewski, Martin Parisot. Analysis of the Riemann Problem for a shallow water model with two velocities. SIAM Journal on Mathematical Analysis, 2018, ⟨10.1137/17M1152887⟩. ⟨hal-01618722v2⟩
863 Consultations
995 Téléchargements
