Generalized incompressible flows, multi-marginal transport and Sinkhorn algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2018
Starting from Brenier's relaxed formulation of the incompress-ible Euler equation in terms of geodesics in the group of measure-preserving diffeomorphisms, we propose a numerical method based on Sinkhorn's algorithm for the entropic regularization of optimal transport. We also make a detailed comparison of this entropic regular-ization with the so-called Bredinger entropic interpolation problem (see [1]). Numerical results in dimension one and two illustrate the feasibility of the method.
euler-entropic-november.pdf (2.08 Mo) Télécharger le fichier
hal-01621311 , version 1 (23-10-2017)
hal-01621311 , version 2 (05-03-2018)
  • HAL Id : hal-01621311 , version 2
Jean-David Benamou, Guillaume Carlier, Luca Nenna. Generalized incompressible flows, multi-marginal transport and Sinkhorn algorithm. Numerische Mathematik, 2018. ⟨hal-01621311v2⟩
1382 Consultations
286 Téléchargements
