Uniform Estimation of a Constant Issued from a Fluid-Structure Interaction Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We prove that the domain obtained by small perturbation of a Lipschtz domain is the union of a star-shaped domains with respect to every point of balls, such that the radius of the balls is independent of the perturbation. This result is useful in order to get uniform estimation for a fluid-structure interaction problem.
447583_1_En_27_Chapter.pdf (301.23 Ko) Télécharger le fichier
hal-01626880 , version 1 (31-10-2017)
Paternité
Andrei Halanay, Cornel Marius Murea. Uniform Estimation of a Constant Issued from a Fluid-Structure Interaction Problem. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.292-301, ⟨10.1007/978-3-319-55795-3_27⟩. ⟨hal-01626880⟩
92 Consultations
94 Téléchargements
