Parameter Estimation in a Size-Structured Population Model with Distributed States-at-Birth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Azmy S. Ackleh
  • Fonction : Auteur
  • PersonId : 1021969
Xinyu Li
  • Fonction : Auteur
  • PersonId : 1021970
Baoling Ma
  • Fonction : Auteur
  • PersonId : 1021971
A least-squares method is developed for estimating parameters in a size-structured population model with distributed states-at-birth from field data. First and second order finite difference schemes for approximating the nonlinear-nonlocal partial differential equation model are utilized in the least-squares problem. Convergence results for the computed parameters are established. Numerical results demonstrating the efficiency of the technique are provided.
447583_1_En_3_Chapter.pdf (407.62 Ko) Télécharger le fichier
hal-01626901 , version 1 (31-10-2017)
Paternité
Azmy S. Ackleh, Xinyu Li, Baoling Ma. Parameter Estimation in a Size-Structured Population Model with Distributed States-at-Birth. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.43-57, ⟨10.1007/978-3-319-55795-3_3⟩. ⟨hal-01626901⟩
31 Consultations
70 Téléchargements
