Control Methods for the Optimization of Plasma Scenarios in a Tokamak - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jacques Blum
Cédric Boulbe
Blaise Faugeras
Holger Heumann
This paper presents the modelling of the evolution of plasma equilibrium in the presence of external poloidal field circuits and passive structures. The optimization of plasma scenarios is formulated as an optimal control problem where the equations for the evolution of the plasma equilibrium are the constraints. The procedure determines the voltages applied to the external circuits that minimize a certain cost-function representing the distance to a desired plasma augmented by an energetic cost of the electrical system. A sequential quadratic programming method is used to solve the minimization of the cost-function and an application to the optimization of a discharge for ITER is shown.
447583_1_En_1_Chapter.pdf (4.13 Mo) Télécharger le fichier
hal-01626908 , version 1 (31-10-2017)
Paternité
Jacques Blum, Cédric Boulbe, Blaise Faugeras, Holger Heumann. Control Methods for the Optimization of Plasma Scenarios in a Tokamak. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.1-20, ⟨10.1007/978-3-319-55795-3_1⟩. ⟨hal-01626908⟩
558 Consultations
145 Téléchargements
