Sparsity Constrained Image Restoration: An Approach Using the Newton Projection Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Image restoration under sparsity constraints has received increased attention in recent years. This problem can be formulated as a nondifferentiable convex optimization problem whose solution is challenging. In this work, the non-differentiability of the objective is addressed by reformulating the image restoration problem as a nonnegatively constrained quadratic program which is then solved by a specialized Newton projection method where the search direction computation only requires matrix-vector operations. A comparative study with state-of-the-art methods is performed in order to illustrate the efficiency and effectiveness of the proposed approach.
447583_1_En_32_Chapter.pdf (816.14 Ko) Télécharger le fichier
hal-01626912 , version 1 (31-10-2017)
Paternité
Germana Landi. Sparsity Constrained Image Restoration: An Approach Using the Newton Projection Method. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.341-350, ⟨10.1007/978-3-319-55795-3_32⟩. ⟨hal-01626912⟩
41 Consultations
79 Téléchargements
