Towards generic adiabatic elimination for bipartite open quantum systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quantum Science and Technology Année : 2017
We consider a composite open quantum system consisting of a fast subsystem coupled to a slow one. Using the time scale separation, we develop an adiabatic elimination technique to derive at any order the reduced model describing the slow subsystem. The method, based on an asymptotic expansion and geometric singular perturbation theory, ensures the physical interpretation of the reduced second-order model by giving the reduced dynamics in a Lindblad form and the state reduction in Kraus map form. We give explicit second-order formulas for Hamiltonian or cascade coupling between the two subsystems. These formulas can be used to engineer, via a careful choice of the fast subsystem, the Hamiltonian and Lindbald operators governing the dissipative dynamics of the slow subsystem.
1704.00785.pdf (276.52 Ko) Télécharger le fichier
hal-01634588 , version 1 (20-09-2023)
Rémi Azouit, Francesca C Chittaro, Alain Sarlette, Pierre Rouchon. Towards generic adiabatic elimination for bipartite open quantum systems. Quantum Science and Technology, 2017, 2 (4), pp.1-15. ⟨10.1088/2058-9565/aa7f3f⟩. ⟨hal-01634588⟩
592 Consultations
26 Téléchargements
