When Does Memory Speed-up Mixing?
We investigate under which conditions a higher-order Markov chain, or more generally a Markov chain on an extended state space, can mix faster than a standard Markov chain on a graph of interest. We find that, depending on the constraints on the dynamics, two very different scenarios can emerge: under strict invariance of the target marginal and for general initialization of the lifted chain no speedup is possible; on the other hand, if these requirements are both relaxed, the lifted dynamics can achieve mixing in a time that corresponds to the diameter of the graph, which is optimal.
