Single-pass Incremental Force Updates for Adaptively Restrained Molecular Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Chemistry Année : 2018
Adaptively Restrained Molecular dynamics (ARMD) allows users to perform more integration steps in wall-clock time by switching on and off positional degrees of freedoms. This article presents new, single-pass incremental force updates algorithms to efficiently simulate a system using ARMD. We assessed different algorithms for speedup measurements and implemented them in the LAMMPS MD package. We validated the single-pass incremental force update algorithm on four different benchmarks using diverse pair potentials. The proposed algorithm allows us to perform simulation of a system faster than traditional MD in both NVE and NVT ensembles. Moreover, ARMD using the new single-pass algorithm speeds up the convergence of observables in wall-clock time.
Singh_singlepass.pdf (4.42 Mo) Télécharger le fichier
hal-01635863 , version 1 (15-11-2017)
Krishna Kant Singh, Stephane Redon. Single-pass Incremental Force Updates for Adaptively Restrained Molecular Dynamics. Journal of Computational Chemistry, 2018, 39 (8), pp.412-423. ⟨10.1002/jcc.25126⟩. ⟨hal-01635863⟩
175 Consultations
235 Téléchargements
