Visualizing and Fabricating Complex Internal Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2017
Visualisation et fabrication de structures internes complexes
Sylvain Lefebvre
  • Fonction : Auteur
  • PersonId : 861797
Additive manufacturing enables the fabrication of complex internal structures akin to foams within shapes. These fine scale structures modify the large scale properties of the shape, for instance making it lighter while preserving sufficient rigidity, or creating porosities enabling fluids to traverse. Triangle meshes are not well suited for modeling and visualizing such structures. Instead, several approaches have been proposed to model them as implicit solids, described by an indicator function returning 1 when a point lies within the solid and 0 outside. Such representations are very compact in memory, however interactive visualization and efficient processing for fabrication can become difficult. This stems from the fact that to visualize or fabricate the structure, the function must be queried at a high sampling rate. This results in a slow and memory intensive process. In this paper we discuss our approach for dealing with such complex structures in the context of interactive modeling for additive manufacturing. We describe an algorithm for the progressive rendering of the structures, as well as an efficient slicing procedure for preparing the geometries for fabrication.
La fabrication additive permet d'intégrer aux objets des structures complexes, ressemblant à des mousses. Ces détails de petite échelle modifient les propriétés à grande échelle de l'objet, par exemple en l'allégeant ou en créant des porosités qui permettent à des fluides de circuler en son sein. Les maillages triangulaires ne sont pas bien adaptés à la modélisation et à la visualisation de ce type de géométries. Des méthodes alternatives ont été proposées, notamment pour les modéliser sous forme de solides implicites, défini par une fonction indicatrice qui renvoie 1 lorsqu'un point est solide et 0 à l'extérieur. Ces représentations sont très compactes en mémoire, cependant leur visualisation interactive et leur préparation efficace peut devenir coûteuse. Ceci vient du fait que pour visualiser et préparer la structure pour le processus de fabrication, il faut échantilloner la fonction indicatrice avec un pas de discrétisation très fin, ce qui induit de longs temps de calcul et requiert une grande quantité de mémoire. Dans cet article nous discutons d'une approche pour visualiser et modéliser interactivement ce type de structures, dans le contexte de la fabrication additive. Nous décrivons un algorithme pour l'affichage progressif de structures complexes, ainsi qu'un algorithme de tranchage efficace pour la fabrication additive.
RT-0493.pdf (4.83 Mo) Télécharger le fichier
hal-01636963 , version 1 (17-11-2017)
hal-01636963 , version 2 (08-03-2018)
  • HAL Id : hal-01636963 , version 2
Sylvain Lefebvre. Visualizing and Fabricating Complex Internal Structures. [Technical Report] RT-0493, Inria Nancy - Grand Est. 2017, pp.15. ⟨hal-01636963v2⟩
313 Consultations
202 Téléchargements
