Krylov methods applied to reactive transport models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reactive transport models couple advection dispersion equations with chemistry equations. If the reactions are at thermodynamic equilibrium, then the system is a set of partial differential and algebraic equations. After space and implicit time discretizations, a nonlinear system of equations must be solved at each time step. The Jacobian matrix of the nonlinear system can be written with a Kronecker product coupling transport and chemistry. Krylov methods are well-suited to solve such linear systems because the matrix vector product can be done efficiently. The main challenge is to design a preconditioning matrix. We propose here to use the special structure of the matrix. Preliminary experiments show that Krylov methods are much more efficient than a direct method which does not use the coupled structure.
siamgs2017-erhel.pdf (569.25 Ko) Télécharger le fichier
hal-01646268 , version 1 (23-11-2017)
  • HAL Id : hal-01646268 , version 1
Jocelyne Erhel. Krylov methods applied to reactive transport models. SIAM Conference on Mathematical and Computational Issues in the Geosciences, Sep 2017, Erlangen, Germany. ⟨hal-01646268⟩
389 Consultations
24 Téléchargements
