A coherent framework for learning spatiotemporal piecewise-geodesic trajectories from longitudinal manifold-valued data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Imaging Sciences Année : 2021
This paper provides a coherent framework for studying longitudinal manifold-valued data. We introduce a Bayesian mixed-effects model which allows estimating both a group-representative piecewise-geodesic trajectory in the Riemannian space of shape and inter-individual variability. We prove the existence of the maximum a posteriori estimate and its asymptotic consistency under reasonable assumptions. Due to the non-linearity of the proposed model, we use a stochastic version of the Expectation-Maximization algorithm to estimate the model parameters. Our simulations show that our model is not noise-sensitive and succeeds in explaining various paths of progression.
2020_ChevallierDebavelaereAllassonniere.pdf (6.76 Mo) Télécharger le fichier
hal-01646298 , version 1 (23-11-2017)
hal-01646298 , version 2 (11-04-2019)
hal-01646298 , version 3 (29-05-2019)
hal-01646298 , version 4 (10-04-2020)
Juliette Chevallier, Vianney Debavelaere, Stéphanie Allassonnière. A coherent framework for learning spatiotemporal piecewise-geodesic trajectories from longitudinal manifold-valued data. SIAM Journal on Imaging Sciences, 2021, 14 (1), pp.349-388. ⟨10.1137/20M1328026⟩. ⟨hal-01646298v4⟩
1165 Consultations
337 Téléchargements
