Two Notions of Differential Equivalence on Sboxes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we discuss two notions of differential equivalence on Sboxes. First, we introduce the notion of DDT-equivalence which applies to vectorial Boolean functions that share the same difference distribution table (DDT). Next, we compare this notion, to what we call the γ-equivalence, applying to vectorial Boolean functions whose DDTs have the same support. We discuss the relation between these two equivalence notions and provide an algorithm for computing the DDT-equivalence and the γ-equivalence classes for a given function. We study the sizes of these classes for some families of Sboxes. Finally, we prove a result that shows that the rows of the DDT of an APN permutation are pairwise distinct.
wcc2017_ddt.pdf (567.48 Ko) Télécharger le fichier
hal-01650010 , version 1 (28-11-2017)
  • HAL Id : hal-01650010 , version 1
Christina Boura, Anne Canteaut, Jérémy Jean, Valentin Suder. Two Notions of Differential Equivalence on Sboxes. WCC 2017 - Workshop on Coding and Cryptography, Sep 2017, Saint Petersburg, Russia. ⟨hal-01650010⟩
272 Consultations
393 Téléchargements
