Descent algorithm for nonsmooth stochastic multiobjective optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Optimization and Applications Année : 2017
Fabrice Poirion
  • Fonction : Auteur
  • PersonId : 1024839
Quentin Mercier
  • Fonction : Auteur
  • PersonId : 1024840
An algorithm for solving the expectation formulation of stochastic nonsmooth multiobjective optimization problems is proposed. The proposed method is an extension of the classical stochastic gradient algorithm to multi-objective optimization using the properties of a common descent vector defined 10 in the deterministic context. The mean square and the almost sure convergence of the algorithm are proven. The algorithm efficiency is illustrated and assessed on an academic example.
articlePQD-COAP.pdf (480.99 Ko) Télécharger le fichier
hal-01660788 , version 1 (11-12-2017)
Fabrice Poirion, Quentin Mercier, Jean-Antoine Desideri. Descent algorithm for nonsmooth stochastic multiobjective optimization. Computational Optimization and Applications, 2017, 68 (2), pp.317-331. ⟨10.1007/s10589-017-9921-x⟩. ⟨hal-01660788⟩
607 Consultations
708 Téléchargements
