Multifidelity surrogate modeling based on Radial Basis Functions
Multiple models of a physical phenomenon are sometimes available with different levels of approximation. The high fidelity model is more computation-ally demanding than the coarse approximation. In this context, including information from the lower fidelity model to build a surrogate model is desirable. Here, the study focuses on the design of a miniaturized photoa-coustic gas sensor which involves two numerical models. First, a multifidelity metamodeling method based on Radial Basis Function, the co-RBF, is proposed. This surrogate model is compared with the classical co-kriging method on two analytical benchmarks and on the photoacoustic gas sensor. Then an extension to the multifidelity framework of an already existing RBF-based optimization algorithm is applied to optimize the sensor efficiency. The co-RBF method brings promising results on a problem in larger dimension and can be considered as an alternative to co-kriging for multifi-delity metamodeling.
