Second order models for optimal transport and cubic splines on the Wasserstein space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations of Computational Mathematics Année : 2019
On the space of probability densities, we extend the Wasserstein geodesics to the case of higher-order interpolation such as cubic spline interpolation. After presenting the natural extension of cubic splines to the Wasserstein space, we propose a simpler approach based on the relaxation of the variational problem on the path space. We explore two different numerical approaches, one based on multi-marginal optimal transport and entropic regularization and the other based on semi-discrete optimal transport.
SplinesWasserstein_final.pdf (1.79 Mo) Télécharger le fichier
hal-01682107 , version 1 (12-01-2018)
hal-01682107 , version 2 (25-07-2018)
Jean-David Benamou, Thomas Gallouët, François-Xavier Vialard. Second order models for optimal transport and cubic splines on the Wasserstein space. Foundations of Computational Mathematics, 2019, ⟨10.1007/s10208-019-09425-z⟩. ⟨hal-01682107v2⟩
176 Consultations
261 Téléchargements
