Approximate Message Passing for sparse matrices with application to the equilibria of large ecological Lotka-Volterra systems
Walid Hachem
Article dans une revue
hal-04000125v2
Actions
Gmail
Facebook
X
LinkedIn
More
Constant step stochastic approximations involving differential inclusions: stability, long-run convergence and applications
Pascal Bianchi
Walid Hachem
Adil Salim
hal-02369439v1
Actions
Gmail
Facebook
X
LinkedIn
More
Analyse et prédiction de séries temporelles multivariées pour la surveillance de la santé d'ouvrages d'art
Fatiha Chabi
Franziska Schmidt
Jean-François Bercher
GRETSI 2023, XXIXème Colloque Francophone de Traitement du Signal et des Images , Aug 2023, Grenoble, France
Communication dans un congrès
hal-04174436v1
Actions
Gmail
Facebook
X
LinkedIn
More
BRANE Clust: Cluster-Assisted Gene Regulatory Network Inference Refinement
Aurélie Pirayre
Camille Couprie
Laurent Duval
Jean-Christophe Pesquet
IEEE/ACM Transactions on Computational Biology and Bioinformatics , 2018, 15 (3), pp.850-860.
⟨10.1101/114769⟩
hal-01330638v1
Actions
Gmail
Facebook
X
LinkedIn
More
Inverse Consistency by Construction for Multistep Deep Registration
Hastings Greer
Lin Tian
François-Xavier Vialard
Roland Kwitt
Sylvain Bouix
et al.
hal-04435861v1
Actions
Gmail
Facebook
X
LinkedIn
More
Minimizing acceleration on the group of diffeomorphisms and its relaxation
Rabah Tahraoui
hal-04497577v1
Actions
Gmail
Facebook
X
LinkedIn
More
The Unbalanced Gromov Wasserstein Distance: Conic Formulation and Relaxation
Thibault Séjourné
Gabriel Peyré
hal-04435914v1
Actions
Gmail
Facebook
X
LinkedIn
More
Snake: a stochastic proximal gradient algorithm for regularized problems over large graphs
Adil Salim
Pascal Bianchi
Walid Hachem
IEEE Transactions on Automatic Control , 2018
hal-02287871v1
Actions
Gmail
Facebook
X
LinkedIn
More
A Gradient Sampling Algorithm for Stratified Maps with Applications to Topological Data Analysis
Jacob Leygonie
Mathieu Carrière
Théo Lacombe
Steve Oudot
hal-03330940v2
Actions
Gmail
Facebook
X
LinkedIn
More
Parameter tuning and model selection in optimal transport with semi-dual Brenier formulation
Adrien Vacher
NeurIPS , 2022, New Orleans, France
hal-03475455v2
Actions
Gmail
Facebook
X
LinkedIn
More
A Multicore Convex Optimization Algorithm with Applications to Video Restoration
Feriel Abboud
Emilie Chouzenoux
Hugues Talbot
IEEE International Conference on Image Processing , Oct 2018, Athens, Greece
hal-01862210v1
Actions
Gmail
Facebook
X
LinkedIn
More
On the asymptotic distribution of the maximum sample spectral coherence of Gaussian time series in the high dimensional regime
Alexis Rosuel
Philippe Loubaton
Pascal Vallet
2021
Pré-publication, Document de travail
hal-03268401v1
Actions
Gmail
Facebook
X
LinkedIn
More
A CLT for linear spectral statistics of large random information-plus-noise matrices
Marwa Banna
Jamal Najim
Jianfeng Yao
2019
hal-01768589v2
Actions
Gmail
Facebook
X
LinkedIn
More
Langevin-based Strategy for Efficient Proposal Adaptation in Population Monte Carlo
Víctor Elvira
Emilie Chouzenoux
ICASSP 2019 - 2019 IEEE International Conference on Acoustics, Speech and Signal Processing , May 2019, Brighton, United Kingdom.
⟨10.1109/ICASSP.2019.8682284⟩
hal-02431677v1
Actions
Gmail
Facebook
X
LinkedIn
More
Low Complexity Adaptive ML Approaches for End-to-End Latency Prediction
Pierre Larrenie
Olivier Venard
Iyad Lahsen-Cherif
hal-03958182v1
Actions
Gmail
Facebook
X
LinkedIn
More
On Learning Parametric Distributions from Quantized Samples
Septimia Sarbu
Abdellatif Zaidi
hal-04456106v1
Actions
Gmail
Facebook
X
LinkedIn
More
Probabilistic modeling and inference for sequential space-varying blur identification
Yunshi Huang
Emilie Chouzenoux
Víctor Elvira
hal-03225842v1
Actions
Gmail
Facebook
X
LinkedIn
More
More Communication Does Not Result in Smaller Generalization Error in Federated Learning
Romain Chor
Milad Sefidgaran
Abdellatif Zaidi
IEEE Symposium on Information Theory (ISIT) , 2023, Taipei, Taiwan
hal-04457317v1
Actions
Gmail
Facebook
X
LinkedIn
More
Testing Uncorrelation of Multi-Antenna Signals Using Linear Spectral Statistics of the Spatio-Temporal Sample Autocorrelation Matrix
Philippe Loubaton
Xavier Mestre
hal-04322837v1
Actions
Gmail
Facebook
X
LinkedIn
More
Achievable rate regions for cooperative cognitive radio networks with complex channels and circular normal additive noises
Anne Savard
E. Veronica Belmega
XXVIIIème Colloque Francophone de Traitement du Signal et des Images, GRETSI 2022 , Sep 2022, Nancy, France
hal-03814060v1
Actions
Gmail
Facebook
X
LinkedIn
More
Stochastic optimization with momentum: convergence, fluctuations, and traps avoidance
Anas Barakat
Pascal Bianchi
Walid Hachem
Sholom Schechtman
hal-03310455v1
Actions
Gmail
Facebook
X
LinkedIn
More
Mixed Delay Constraints on a Fading C-RAN Uplink
Homa Nikbakht
Michèle Wigger
Walid Hachem
Shlomo Shamai Shitz
IEEE Information Theory Workshop (ITW) , 2019, Visby, Sweden
hal-02385497v1
Actions
Gmail
Facebook
X
LinkedIn
More
An Auxiliary Variable Method for Markov Chain Monte Carlo Algorithms in High Dimension
Yosra Marnissi
Emilie Chouzenoux
Amel Benazza-Benyahia
hal-01797093v1
Actions
Gmail
Facebook
X
LinkedIn
More
Les grandes matrices aléatoires : un aperçu historique
Walid Hachem
GRETSI , Sep 2022, Nancy, France
hal-03817828v1
Actions
Gmail
Facebook
X
LinkedIn
More
RipsNet: a general architecture for fast and robust estimation of the persistent homology of point clouds
Felix Hensel
Marc Glisse
Frédéric Chazal
Thibault de Surrel
Mathieu Carriere
et al.
Proceedings of Machine Learning Research , 2022, Proceedings of Topological, Algebraic, and Geometric Learning Workshops 2022, 196, pp.96-106
hal-03867083v1
Actions
Gmail
Facebook
X
LinkedIn
More
Faster Unbalanced Optimal Transport: Translation invariant Sinkhorn and 1-D Frank-Wolfe
Gabriel Peyré
François Vialard
Thibault Séjourné
Proceedings of The 25th International Conference on Artificial Intelligence and Statistics , Mar 2022, 2022-03-28, France. pp.4995-5021
hal-03869544v1
Actions
Gmail
Facebook
X
LinkedIn
More
ULOOF: a User Level Online Offloading Framework for Mobile Edge Computing
José L. D. Neto
Se-Young Yu
Daniel Fernandes Macedo
José-Marcos Nogueira
Rami Langar
et al.
hal-01547036v2
Actions
Gmail
Facebook
X
LinkedIn
More
Rétrodiffusion coopérative efficace en énergie pour un système multi-utilisateurs à accès multiple NOMA
Hajar El Hassani
Anne Savard
E Belmega
Rodrigo C. De Lamare
hal-03691782v2
Actions
Gmail
Facebook
X
LinkedIn
More
Emptiness problems for distributed automata
Antti Kuusisto
Fabian Reiter
hal-03678048v1
Actions
Gmail
Facebook
X
LinkedIn
More
A Shooting Formulation of Deep Learning
Roland Kwitt
Susan Wei
Marc Niethammer
2020
hal-02871236v2
Actions
Gmail
Facebook
X
LinkedIn
More
