The Unbalanced Gromov Wasserstein Distance: Conic Formulation and Relaxation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thibault Séjourné
  • Fonction : Auteur
Gabriel Peyré
  • Fonction : Auteur
Comparing metric measure spaces (i.e. a metric space endowed with aprobability distribution) is at the heart of many machine learning problems. The most popular distance between such metric measure spaces is theGromov-Wasserstein (GW) distance, which is the solution of a quadratic assignment problem. The GW distance is however limited to the comparison of metric measure spaces endowed with a probability distribution. To alleviate this issue, we introduce two Unbalanced Gromov-Wasserstein formulations: a distance and a more tractable upper-bounding relaxation.They both allow the comparison of metric spaces equipped with arbitrary positive measures up to isometries. The first formulation is a positive and definite divergence based on a relaxation of the mass conservation constraint using a novel type of quadratically-homogeneous divergence. This divergence works hand in hand with the entropic regularization approach which is popular to solve large scale optimal transport problems. We show that the underlying non-convex optimization problem can be efficiently tackled using a highly parallelizable and GPU-friendly iterative scheme. The second formulation is a distance between mm-spaces up to isometries based on a conic lifting. Lastly, we provide numerical experiments onsynthetic examples and domain adaptation data with a Positive-Unlabeled learning task to highlight the salient features of the unbalanced divergence and its potential applications in ML.
Fichier non déposé
hal-04435914 , version 1 (02-02-2024)
Thibault Séjourné, François-Xavier Vialard, Gabriel Peyré. The Unbalanced Gromov Wasserstein Distance: Conic Formulation and Relaxation. NeurIPS, 2021, Virtual conference, France. ⟨10.48550/arXiv.2009.04266⟩. ⟨hal-04435914⟩
14 Consultations
0 Téléchargements
