On Learning Parametric Distributions from Quantized Samples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of learning parametric distributions from their quantized samples in a network. Specifically, n agents or sensors observe independent samples of an unknown parametric distribution; and each of them uses k bits to describe its observed sample to a central processor whose goal is to estimate the unknown distribution. First, we establish a generalization of the well-known van Trees inequality to general Lp-norms, with p > 1, in terms of Generalized Fisher information. Then, we develop minimax lower bounds on the estimation error for two losses: general Lp-norms and the related Wasserstein loss from optimal transport.
hal-04456106 , version 1 (13-02-2024)
Septimia Sarbu, Abdellatif Zaidi. On Learning Parametric Distributions from Quantized Samples. 2021 IEEE International Symposium on Information Theory (ISIT), Jul 2021, Melbourne, France. pp.1094-1099, ⟨10.1109/ISIT45174.2021.9518103⟩. ⟨hal-04456106⟩
11 Consultations
0 Téléchargements
