A Multicore Convex Optimization Algorithm with Applications to Video Restoration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, we present a new distributed algorithm for minimizing a sum of non-necessarily differentiable convex functions composed with arbitrary linear operators. The overall cost function is assumed strongly convex. Each involved function is associated with a node of a hypergraph having the ability to communicate with neighboring nodes sharing the same hyperedge. Our algorithm relies on a primal-dual splitting strategy with established convergence guarantees. We show how it can be efficiently implemented to take full advantage of a multicore architecture. The good numerical performance of the proposed approach is illustrated in a problem of video sequence denoising, where a significant speedup is achieved.
Template.pdf (474.69 Ko) Télécharger le fichier
hal-01862210 , version 1 (27-08-2018)
  • HAL Id : hal-01862210 , version 1
Feriel Abboud, Emilie Chouzenoux, Jean-Christophe Pesquet, Hugues Talbot. A Multicore Convex Optimization Algorithm with Applications to Video Restoration. IEEE International Conference on Image Processing, Oct 2018, Athens, Greece. ⟨hal-01862210⟩
166 Consultations
220 Téléchargements
