Constant step stochastic approximations involving differential inclusions: stability, long-run convergence and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics: An International Journal of Probability and Stochastic Processes Année : 2019
Approximation stochastique à pas constant et inclusions différentielles : stabilité, convergence à long terme et applications
We consider a Markov chain (xn) whose kernel is indexed by a scaling parameter γ > 0, referred to as the step size. The aim is to analyze the behavior of the Markov chain in the doubly asymptotic regime where n → ∞ then γ → 0. First, under mild assumptions on the so-called drift of the Markov chain, we show that the interpolated process converges narrowly to the solutions of a Differential Inclusion (DI) involving an upper semicontinuous set-valued map with closed and convex values. Second, we provide verifiable conditions which ensure the stability of the iterates. Third, by putting the above results together, we establish the long run convergence of the iterates as γ → 0, to the Birkhoff center of the DI. The ergodic behavior of the iterates is also provided. Application examples are investigated. We apply our findings to 1) the problem of nonconvex proximal stochastic optimization and 2) a fluid model of parallel queues.
revised_dicst.pdf (476.91 Ko) Télécharger le fichier
hal-02369439 , version 1 (19-11-2019)
Pascal Bianchi, Walid Hachem, Adil Salim. Constant step stochastic approximations involving differential inclusions: stability, long-run convergence and applications. Stochastics: An International Journal of Probability and Stochastic Processes, 2019, 91 (2), pp.288-320. ⟨10.1080/17442508.2018.1539086⟩. ⟨hal-02369439⟩
59 Consultations
88 Téléchargements
