BACKWARD DIFFERENTIATION FORMULA FINITE DIFFERENCE SCHEMES FOR DIFFUSION EQUATIONS WITH AN OBSTACLE TERM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Olivier Bokanowski
Kristian Debrabant
  • Fonction : Auteur
Finite difference schemes, using Backward Differentiation Formula (BDF), are studied for the approximation of one-dimensional diffusion equations with an obstacle term, of the form $$\min(v_t - a(t,x) v_{xx} + b(t,x) v_x + r(t,x) v, v- \varphi(t,x))= f(t,x).$$ For the scheme building on BDF2, we discuss unconditional stability, prove an $L^2$-error estimate and show numerically second order convergence, in both space and time, unconditionally on the ratio of the mesh steps. In the analysis, an equivalence of the obstacle equation with a Hamilton-Jacobi-Bellman equation is mentioned, and a Crank-Nicolson scheme is tested in this context. Two academic problems for parabolic equations with an obstacle term with explicit solutions and the American option problem in mathematical finance are used for numerical tests.
main.pdf (574 Ko) Télécharger le fichier
hal-01686742 , version 1 (18-01-2018)
hal-01686742 , version 2 (06-03-2020)
  • HAL Id : hal-01686742 , version 1
Olivier Bokanowski, Kristian Debrabant. BACKWARD DIFFERENTIATION FORMULA FINITE DIFFERENCE SCHEMES FOR DIFFUSION EQUATIONS WITH AN OBSTACLE TERM. 2019. ⟨hal-01686742v1⟩
729 Consultations
1632 Téléchargements
