Stretch Factor in a Planar Poisson-Delaunay Triangulation with a Large Intensity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Probability Année : 2018
Let $X := X_n ∪ \{(0, 0), (1, 0)\}$, where $X_n$ is a planar Poisson point process of intensity $n$. We provide a first non-trivial lower bound for the distance between the expected length of the shortest path between (0, 0) and (1, 0) in the Delaunay triangulation associated with $X$ when the intensity of $X_n$ goes to infinity. Simulations indicate that the correct value is about 1.04. We also prove that the expected length of the so-called upper path converges to $35/3\pi^2$, giving an upper bound for the expected length of the smallest path.
AP16381.pdf (1.06 Mo) Télécharger le fichier
vignette 2.png (31.72 Ko) Télécharger le fichier
Format : Figure, Image
hal-01700778 , version 1 (05-02-2018)
Nicolas Chenavier, Olivier Devillers. Stretch Factor in a Planar Poisson-Delaunay Triangulation with a Large Intensity. Advances in Applied Probability, 2018, 50 (1), pp.35-56. ⟨10.1017/apr.2018.3⟩. ⟨hal-01700778⟩
271 Consultations
195 Téléchargements
