Convergence of a Degenerate Microscopic Dynamics to the Porous Medium Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Annales de l'Institut Fourier Année : 2019
We derive the porous medium equation from an interacting particle system which belongs to the family of exclusion processes, with nearest neighbor exchanges. The particles follow a degenerate dynamics, in the sense that the jump rates can vanish for certain configurations, and there exist blocked configurations that cannot evolve. In [7] it was proved that the macroscopic density profile in the hydrodynamic limit is governed by the porous medium equation (PME), for initial densities uniformly bounded away from 0 and 1. In this paper we consider the more general case where the density can take those extreme values. In this context, the PME solutions display a richer behavior, like moving interfaces, finite speed of propagation and breaking of regularity. As a consequence, the standard techniques that are commonly used to prove this hydrodynamic limits cannot be straightforwardly applied to our case. We present here a way to generalize the relative entropy method, by involving approximations of solutions to the hydrodynamic equation, instead of exact solutions.
PME_BlondelCancesSasadaSimon-corrections.pdf (302.4 Ko) Télécharger le fichier
hal-01710628 , version 1 (16-02-2018)
hal-01710628 , version 2 (26-04-2018)
hal-01710628 , version 3 (17-07-2019)
  • HAL Id : hal-01710628 , version 3
Oriane Blondel, Clément Cancès, Makiko Sasada, Marielle Simon. Convergence of a Degenerate Microscopic Dynamics to the Porous Medium Equation. inPress. ⟨hal-01710628v3⟩
543 Consultations
175 Téléchargements
