A new criterion for boundedness of solutions for a class of periodic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
A wide range of practical systems exhibits dynamics , which are periodic with respect to several state variables and which possess multiple invariant solutions. Yet, when analyzing stability of such systems, many classical techniques often fall short in that they only permit to establish local stability properties. Motivated by this, we present a new sufficient criterion for global stability of such a class of nonlinear systems. The proposed approach is characterized by two main properties. First, it develops the conventional cell structure framework to the case of multiple periodic states. Second, it extends the standard Lyapunov theory by relaxing the usual definiteness requirements of the employed Lyapunov functions to sign-indefinite functions.
ECC18_Johannes_A.pdf (240.57 Ko) Télécharger le fichier
hal-01755084 , version 1 (30-03-2018)
  • HAL Id : hal-01755084 , version 1
Denis Efimov, Johannes Schiffer. A new criterion for boundedness of solutions for a class of periodic systems. Proc. 17th European Control Conference (ECC), Jun 2018, Limassol, Cyprus. ⟨hal-01755084⟩
115 Consultations
152 Téléchargements
