Biomechanics-based graph matching for augmented CT-CBCT
Jaime Garcia Guevara 1 Igor Peterlik 1 Marie-Odile Berger 2 Stephane Cotin 1
2 MAGRIT - Visual Augmentation of Complex Environments
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : Purpose: Augmenting intraoperative cone beam computed tomography (CBCT) images with preoperative computed tomography (CT) data in the context of image-guided liver therapy. The expected benefit is an improved visualization of tu-mor(s), vascular system and other internal structures of interest. Method: An automatic elastic registration based on matching of vascular trees extracted from both the preoperative and intraoperative images. Although methods dedicated to non-rigid graph matching exist, they are not efficient when large in-traoperative deformations of tissues occur, as is the case during the liver surgery. The contribution is an extension of the graph matching algorithm using Gaussian process regression (GPR) [1]: First, an improved GPR matching is introduced by imposing additional constraints during the matching when the number of hypothesis is large; like the original algorithm, this extended version does not require a manual initialization of matching. Second, a fast biomechanical model is employed to make the method capable of handling large deformations. Results: The proposed automatic intraoperative augmentation is evaluated on both synthetic and real data. that the algorithm is capable of handling large deformations , thus being more robust and reliable than previous approaches. Moreover, the time required to perform the elastic registration is compatible with the intraopera-tive navigation scenario. Conclusion: A biomechanics-based graph matching method, which can handle large deformations and augment intraoperative CBCT, is presented and evaluated.
Type de document :
Article dans une revue
International Journal of Computer Assisted Radiology and Surgery, Springer Verlag, 2018, 13 (6), pp.805-813. 〈10.1007/s11548-018-1755-1〉
Liste complète des métadonnées
Littérature citée [2 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01761521
Contributeur : Jaime Garcia Guevara <>
Soumis le : vendredi 13 juillet 2018 - 15:40:27
Dernière modification le : mardi 18 décembre 2018 - 16:18:26
Fichier
template.pdf
Fichiers produits par l'(les) auteur(s)
Citation
Jaime Garcia Guevara, Igor Peterlik, Marie-Odile Berger, Stephane Cotin. Biomechanics-based graph matching for augmented CT-CBCT. International Journal of Computer Assisted Radiology and Surgery, Springer Verlag, 2018, 13 (6), pp.805-813. 〈10.1007/s11548-018-1755-1〉. 〈hal-01761521v2〉
Métriques
Consultations de la notice
434
Téléchargements de fichiers
95
