Averaging Optimal Control Systems with Two Fast Variables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Averaging is a valuable technique to gain understanding in the long-term evolution of dynamical systems characterized by slow and fast dynamics. Recent contributions proved that averaging can be applied to the extremal flow of optimal control problems. The present work extends these results by tackling averaging of time optimal systems with two fast variables. The first outcome consists of a justification of the application of the averaging principle to this problem. The key role of the adjoints of fast variables is then disclosed, which yields the assessment of a compatibility condition between that their boundary values in the original and averaged systems. A simplified relation is also obtained when a single fast variable is considered. The second outcome is devoted to the a posteriori reconstruction of short-period variations. The classical near-identity transformation exploited in dynamical system theory is shown to be inadequate to restore the adjoints of slow variables because of the peculiar form of their equations of motion. Hence, a consistent transformation is developed. Resonance effects are finally discussed. The methodology is applied to a time-optimal low-thrust orbital transfer in the Earth-Moon system.
averaging2freq.pdf (513.7 Ko) Télécharger le fichier
hal-01793704 , version 1 (16-05-2018)
hal-01793704 , version 2 (11-01-2022)
hal-01793704 , version 3 (31-01-2022)
hal-01793704 , version 4 (22-04-2022)
  • HAL Id : hal-01793704 , version 1
Lamberto Dell'Elce, Jean-Baptiste Caillau, Jean-Baptiste Pomet. Averaging Optimal Control Systems with Two Fast Variables. 2018. ⟨hal-01793704v1⟩
412 Consultations
240 Téléchargements
