Considerations on Two-Phase Averaging of Time-Optimal Control Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Averaging is a valuable technique to gain understanding in the long-term evolution of dynamical systems characterized by slow dynamics and fast periodic or quasi-periodic dynamics. The authors recently proved that averaging can be applied to the extremal flow of optimal control problems with one fast variable, with a special treatment of the adjoint of the fast variable. The present work extends these results by tackling averaging of time optimal systems with two fast variables, that is considerably more complex due to resonances. No general theory is presented, but rather a thorough treatement of an example, based on numerical experiments After providing a justification of the possibility to use averaging techniques in this problem "away form resonances" and discussing compatibility conditions between adjoint variables of the original and averaged systems, we analyze numerically the impact of resonance crossings on the dynamics of adjoint variables. Resonant averaged forms (with one less avaraging variable) are used to model the effect of resonances and cross them without loosing the accuracy of the averaging prediction.
averaging2freq.pdf (473.4 Ko) Télécharger le fichier
hal-01793704 , version 1 (16-05-2018)
hal-01793704 , version 2 (11-01-2022)
hal-01793704 , version 3 (31-01-2022)
hal-01793704 , version 4 (22-04-2022)
  • HAL Id : hal-01793704 , version 2
Lamberto Dell'Elce, Jean-Baptiste Caillau, Jean-Baptiste Pomet. Considerations on Two-Phase Averaging of Time-Optimal Control Systems. 2022. ⟨hal-01793704v2⟩
409 Consultations
239 Téléchargements
