On the use of the sterile insect technique or the incompatible insect technique to reduce or eliminate mosquito populations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Vector control is critical to limit the circulation of vector-borne diseases like chikungunya, dengue or zika which have become important issues around the world. Among them the Sterile Insect Technique (SIT) and the Incompatible Insect Technique (IIT) recently aroused a renewed interest. In this paper we derive and study a minimalistic mathematical model designed for Aedes mosquito population elimination by SIT/IIT. Contrary to most of the previous models, it is bistable in general, allowing simultaneously for elimination of the population and for its survival. We consider dierent types of releases (constant, periodic or impulsive) and show necessary conditions to reach elimination in each case. We also estimate both sucient and minimal treatment times. Biological parameters are estimated from a case study of an Aedes polynesiensis population, for which extensive numerical investigations illustrate the analytical results. The applications of this work are twofold: to help identifying some key parameters that may need further eld investigations, and to help designing release protocols.
sterilizingmales-Part1.pdf (834.39 Ko) Télécharger le fichier
hal-01799954 , version 1 (25-05-2018)
Martin Strugarek, Herve Bossin, Yves Dumont. On the use of the sterile insect technique or the incompatible insect technique to reduce or eliminate mosquito populations. 2018. ⟨hal-01799954⟩
547 Consultations
242 Téléchargements
