Quantifying the Closeness to a Set of Random Curves via the Mean Marginal Likelihood - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
In this paper, we tackle the problem of quantifying the closeness of a newly observed curve to a given sample of random functions, supposed to have been sampled from the same distribution. We define a probabilistic criterion for such a purpose, based on the marginal density functions of an underlying random process. For practical applications, a class of estimators based on the aggregation of multivariate density estimators is introduced and proved to be consistent. We illustrate the effectiveness of our estimators, as well as the practical usefulness of the proposed criterion, by applying our method to a dataset of real aircraft trajectories.
density_estimation.pdf (1.09 Mo) Télécharger le fichier
hal-01816407 , version 1 (15-06-2018)
  • HAL Id : hal-01816407 , version 1
Cédric Rommel, Frédéric Bonnans, Baptiste Gregorutti, Pierre Martinon. Quantifying the Closeness to a Set of Random Curves via the Mean Marginal Likelihood. 2018. ⟨hal-01816407⟩
216 Consultations
189 Téléchargements
