Interaction between the limbic and sensori-motor cortico-basal loops : a systemic framework to explain animal behaviour - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2018
Interaction between the limbic and sensori-motor cortico-basal loops : a systemic framework to explain animal behavior_NALLAPU_SBDM2018.pdf (1.36 Mo) Télécharger le fichier
hal-01820371 , version 1 (21-06-2018)
  • HAL Id : hal-01820371 , version 1
Bhargav Teja Nallapu, Frédéric Alexandre. Interaction between the limbic and sensori-motor cortico-basal loops : a systemic framework to explain animal behaviour. SBDM 2018 - Eighth International Symposium on Biology of Decision Making, May 2018, Paris, France. ⟨hal-01820371⟩
161 Consultations
95 Téléchargements
