A Multi-metric Algorithm for Hierarchical Clustering of Same-Length Protein Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The identification of meaningful groups of proteins has always been a major area of interest for structural and functional genomics. Successful protein clustering can lead to significant insight, assisting in both tracing the evolutionary history of the respective molecules as well as in identifying potential functions and interactions of novel sequences. Here we propose a clustering algorithm for same-length sequences, which allows the construction of subset hierarchy and facilitates the identification of the underlying patterns for any given subset. The proposed method utilizes the metrics of sequence identity and amino-acid similarity simultaneously as direct measures. The algorithm was applied on a real-world dataset consisting of clonotypic immunoglobulin (IG) sequences from Chronic lymphocytic leukemia (CLL) patients, showing promising results.
468652_1_En_18_Chapter.pdf (1.16 Mo) Télécharger le fichier
hal-01821300 , version 1 (22-06-2018)
Paternité
Sotirios–filippos Tsarouchis, Maria Th. Kotouza, Fotis E. Psomopoulos, Pericles A. Mitkas. A Multi-metric Algorithm for Hierarchical Clustering of Same-Length Protein Sequences. 14th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2018, Rhodes, Greece. pp.189-199, ⟨10.1007/978-3-319-92016-0_18⟩. ⟨hal-01821300⟩
169 Consultations
51 Téléchargements
