Combining Service-Oriented Computing with Embedded Systems - A Robotics Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexander Jungmann
  • Fonction : Auteur
  • PersonId : 1035298
Jan Jatzkowski
  • Fonction : Auteur
  • PersonId : 1035299
Bernd Kleinjohann
  • Fonction : Auteur
  • PersonId : 1035300
In this paper, we introduce an approach for combining embedded systems with Service-oriented Computing techniques based on a concrete application scenario from the robotics domain. Our proposed Service-oriented Architecture allows for incorporating computational expensive functionality as services into a distributed computing environment. Furthermore, our framework facilitates a seamless integration of embedded systems such as robots as service providers into the computing environment. The entire communication is based on so-called recipes, which can be interpreted as autonomous messages that contain all necessary information for executing compositions of services.
467217_1_En_3_Chapter.pdf (1.33 Mo) Télécharger le fichier
hal-01854152 , version 1 (06-08-2018)
Paternité
Alexander Jungmann, Jan Jatzkowski, Bernd Kleinjohann. Combining Service-Oriented Computing with Embedded Systems - A Robotics Case Study. 5th International Embedded Systems Symposium (IESS), Nov 2015, Foz do Iguaçu, Brazil. pp.27-37, ⟨10.1007/978-3-319-90023-0_3⟩. ⟨hal-01854152⟩
116 Consultations
120 Téléchargements
