A UML Profile to Couple the Production Code Generator TargetLink with UML Design Tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
When modelling architecture of complex embedded systems proper architecture languages and tools are necessary. UML [1] has become a proven and well accepted design language to express system as well as software architecture. For definition of internal behavior of components composed and specified during software design, Simulink is commonly used, especially for automotive and aerospace applications. As common practise, code is generated directly from such behavior models. Therefore, code generators such as TargetLink [2] are used. In this paper we propose a UML profile to describe specific properties necessary to adapt UML models to the code generator TargetLink.
467217_1_En_15_Chapter.pdf (206.51 Ko) Télécharger le fichier
hal-01854153 , version 1 (06-08-2018)
Paternité
Malte Falk, Stefan Walter, Achim Rettberg. A UML Profile to Couple the Production Code Generator TargetLink with UML Design Tools. 5th International Embedded Systems Symposium (IESS), Nov 2015, Foz do Iguaçu, Brazil. pp.185-196, ⟨10.1007/978-3-319-90023-0_15⟩. ⟨hal-01854153⟩
59 Consultations
215 Téléchargements
